- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a user who's AuotCAD Mech will crash consistently when certain message prompts are called. An example would be if an SHX file is missing from a drawing. The normal prompt would display saying do you wish to replace the font files but his machine will have a blank unresponsive black box. I check the task manager and see a single core is sat at 100% (13% on his quad core), with no increase in memory usage.
I have tried everything I can think of to eliminate the issue. Clean install of AutoCAD M, remove and install gfx driver (different versions), update direct x, different user profile (in Windows), different profile (In ACAD M). The machine is running XP Pro 32bit.
I think it must be something as OS level which is causing an issue in AutoCAD. Has anybody experienced this before? If so please help me as I am not at the stage of a full system rebuild.
Guy
