AutoCAD Mechanical 2012:
When I right-click my UCS icon in the lower-left of the model space drawing window, a right-click menu (with the commands World, Previous, Named UCS, Rotate View, etc.) should appear but doesn't.
Yet, when I open the plain AutoCAD 2012, this UCS right-click menu works...which made me think it was an option that is either turned off by default or nonexistant in the "Mechanical" version...but my co-worker also uses Mechanical, and his right-click UCS menu works!
I have set my UCS to be "selectable", and that didn't help. I've checked every tab of the "Option"s menu between each version to make sure there's no difference that could cause this problem. I saw nothing that seemed to help.
Does anyone have any ideas what's wrong?
Obviously, I know I can just type "UCS" at the command line, but I want this newer way to work too.
