AutoCAD Mechanical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
UCS right-clic k menu somehow got disabled?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD Mechanical 2012:
When I right-click my UCS icon in the lower-left of the model space drawing window, a right-click menu (with the commands World, Previous, Named UCS, Rotate View, etc.) should appear but doesn't.
Yet, when I open the plain AutoCAD 2012, this UCS right-click menu works...which made me think it was an option that is either turned off by default or nonexistant in the "Mechanical" version...but my co-worker also uses Mechanical, and his right-click UCS menu works!
I have set my UCS to be "selectable", and that didn't help. I've checked every tab of the "Option"s menu between each version to make sure there's no difference that could cause this problem. I saw nothing that seemed to help.
Does anyone have any ideas what's wrong?
Obviously, I know I can just type "UCS" at the command line, but I want this newer way to work too.
Re: UCS right-clic k menu somehow got disabled?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Let me add that my AutoCAD 2012 Mechanical is an upgrade from the original 2011 dvd's.
The problem persists even when I open up AutoCAD 2012 Mechanical and start a new drawing from scratch using the stock "acad.dwt".
Also, I'm wondering if there's any way to get AutoCAD to print out one long text file that has every AutoCAD setting. Then I could do that for both AutoCAD standard and mechanical...and then compare the two to see all the differences that may explain the problem occurring only in mechanical but not in the standard AutoCAD.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I found that changing my profile from <<ACADMPP>> to <<VANILLA>> makes the right-click UCS menu work. That changes many, many other things along with it that I don't want to change, however. But possibly comparing the main customization file .cuix that gets loaded when a user changes from one profile to the other may yield some answers.
For example, <<ACADMPP>> by default has no rollover tooltips set, so even though the Options/Display/Show Tool Tips may be checkboxed, if the .cuix doesn't have some specific property set to show upon rollover, no tooltip happens anyway. I had been wondering about that issue too.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Figured it out.
In the CUI/shortcut menus/ there is an entry called UCS for <<VANILLA>> AutoCAD, but in <<ACADMPP>> AutoCAD Mechanical there is none.
I used the transfer tab on the CUI to load up the acad.cuix and copy its UCS shortcut menu into AutoCAD Mechanical's list of shortcut menus. Problem solved. Now Mechanical has the right-click UCS menu too.
