• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Active Member
    Accepted Solution
    Turn off Annotation Scaling Message box.
    1152 Views, 5 Replies
    07-01-2010 10:46 PM
    When i open a drawing Annotation Scaling Message box appear. How to turn off this message
    Permanently. Please Suggest. refer the screen dump
    Thanks in Advance.
    Sithick.
    Please use plain text.
    Employee
    Re: Turn off Annotation Scaling Message box.
    07-04-2010 09:08 PM in reply to: sast
    You can set sysvar EXPERT to 5.
    Active Member
    07-04-2010 10:15 PM in reply to: cheewec
    Works Great !!!
    Thanks a lot.
    Sithick.
    Distinguished Contributor
    acwtzwegers
    06-15-2012 05:26 AM in reply to: sast
    Has anyone found a better solution to this yet? Who do we have to bribe/threaten/plea to to get annotation scaling finally supported in ACM 20 after it was introduced? Or at least get us a sysvar to switch just this message off (the expert 5 level doesn't work either.. )
    New Member
    12-14-2012 06:51 AM in reply to: sast
    Canceling out of the message can be done with Expert 5, however to get it to work consitently you need to embed it in a LSP routine and run it in the startup suite.
    ;;;LSP Routine
    (defun c:startup()
    (command "expert" "5")
    (c:startup)
    ;;;;LSP Routine
    save above in a plain text file with extension .lsp in a support folder of autocad and then in load applications add in to the startup suite
    acwtzwegers
    12-18-2012 01:43 AM in reply to: kbjones02
    That is still no real option, as most users actually are not expert level 5 and need all the other alerts.
    Autodesk should actually do an actual update on AutoCAD Mechanical (instead of just sticking the Genius/Mechanical shell on a new AutoCAD version - regardless of the bugs - and taking the extra cash for ACM licenses w/o really giving anything back).
    Annotative objects have been in AutoCAD for over a decade now, about time to support them (and Truetype Fonts, and parametics, and dynamic blocks and _paperspace_ (!!!)... you know, stuff that should've been supported already for longer then some users' ages.)
    *grumbles some more*
