• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Valued Contributor
    Start Mechanical with no Drawing open?
    43 Views, 1 Replies
    01-27-2012 05:58 AM
    Hey all,
    I would like to start Mechanical with nothing open. Currently it opens up with a default ansi template, but I would much rather have it open to just the blank screen (as if you had closed said ansi template).
    Is this possible?
    tks!
    Support Admin
    Re: Start Mechanical with no Drawing open?
    01-29-2012 06:43 PM in reply to: Talayoe
    The only option i think of would be to type STARTUP in the command line of Mechanical and set the value to zero.
    This would ask you what you would like to open. If that doesn't suit you, then you have to modify the acad.lsp file to add these changes. Here is an article that talks about it,
    http://www.cadtutor.net/forum/showthread.php?20245-Start-AutoCAD-with-no-new-drawing...
    http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/start-autocad-with-no-drawing-open/td...
    Hope it helps.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
