• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Bob_Zurunkle
    Sectionplane
    461 Views, 6 Replies
    08-05-2011 09:48 AM
    Any ides as to why my sectionplane (and related) commands are not being recognized?
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Sectionplane
    10-04-2011 08:35 PM in reply to: Bob_Zurunkle
    Can you please tell me which command is not working and also which version of mechanical you are running at the moment and the service pack level of the product.
    Looking forward to your reply.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Active Contributor
    Re: Sectionplane
    10-05-2011 02:10 PM in reply to: Bob_Zurunkle
    Hi Bob,
    I found this to be a problem too and did some googling and found an answer. The sectionplane (and related) commands will not work in the Mechanical profile <<ACADMPP>> since they are AutoCAD Vanilla commands. If you load the Vanilla profile <<VANILLA>>, these commands will work. Type Options -> Profiles tab (to switch profiles)
    Autodesk shouldn't have included these commands on the ribbon when you are in the Mechanical profile...I hope they read this...but whatever.
    If you find having to switch between profiles annoying like I do, there is a registry fix to enable "Vanilla" commands in the Mechanical profile.
    Try the following:
    Click the Start menu -> Run
    Type: regedit
    Locate the following path:
    (Note: Your path may be slightly different depending on your version of AutoCAD Mechanical)
    HKEY_CURRENT_USER -> Software -> Autodesk -> AutoCAD -> R18.2 -> ACAD-A005:409 -> Profiles -> <<ACADMMP>>
    On the right you should see a key called "DisableAcadSection"
    Double click on this key and change the value from 1 to 0
    Click OK
    The next time you start AutoCAD Mechanical, the "Vanilla" commands should work.
    Hope this helps.
    Vicki
    Patchy
    Re: Sectionplane
    12-29-2011 07:56 AM in reply to: Vickimcl
    Thanks Vicky for the solution.
    This is for you Autodesk:
    If you bought a car and it doen't run like it should, you take it back and have it repair right away, not waiting a few months.
    Thousand dollars people spent and get this screwed up.
    Ribbon or typing in command SECTIONPLANE does nothing, no Service Pack, no HOTFIX as of today.
    Bob_Zurunkle
    Re: Sectionplane
    12-29-2011 10:00 AM in reply to: Patchy
    Yanno somewhere this all slipped past me including the responses. I have been running mine as straight AutoCAD for quite some time now, except when I need something Mechanical can do for me that nillacad can't...
    Member
    Re: Sectionplane
    09-21-2012 12:15 PM in reply to: Bob_Zurunkle
    Thanks for the great infomation. Big help!!
    New Member
    Re: Sectionplane
    01-24-2013 08:37 AM in reply to: Vickimcl
    thank for suggestion. its helpful..................
