- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Why does power dims have a problem with selecting points in blocks through viewports and getting the correct scale?
I am a pretty advance AutoCAD user, who is just getting used to the idiosyncrasies of AutoCAD Mechanical. So far I'm not very impressed, because Inventor does it (annotation) better. Yet there are some very fundamental problems that regular AutoCAD does not have that are driving me nuts in Mechanical (even now in the latest 2012 version).
Example: I have a drawing that contains a few X-refs (some even nested to the 3rd level or so), Blocks and other basic line work in Modelspace. Then in Paperspace I use all viewports (mview) with my dimensions and leaders pointing through the viewports to the Modelspace resident entities. I thought everything was setup fine, until I watched a member of my staff attempt to use the Power Dimension command '_ampowerdim' to draw a dimension that I usually create using 'dimlinear'. His didn't translate the scale throught the viewport correctly, and gave him paperspace 1:1 scale. So I began to experiement. Turns out this problem only works when you select a block object, not x-ref, not modelspace resident graphic entity.
Is there a setting somewhere, or a bug to be fixed somehow that is preventing ampowerdim, from extracting the proper scale from a regular block?
More info: Block's created using flatshot from 3D Solids (most of the time). Blocks scaled 1:1 in modelspace. Blocks may be rotated, but test problem wasn't nor was it mirrored. Block is not annotative. Block is scaled uniformly. Block has no nested blocks inside, and consists of all lines, arcs, circles, ellipses.
Does anybody else have this same problem?
jvj
