• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Valued Contributor
    Accepted Solution
    Polylines not filled...
    222 Views, 5 Replies
    09-13-2012 01:41 PM
    Polylines are being filled in but according to FILLMODE they are being filled in for both new and existing drawings.
    Although some drawings that I open with PLines are showing them filled in and I can't find the difference between them.
    Any ideas?
    AutoCAD Mechnical 2012
    Please use plain text.
    Product Support
    Volker_C
    Re: Polylines not filled...
    09-20-2012 03:02 PM in reply to: KF090
    Are you still having problems with the Fillmode system variable?  When you state that FIllmode shows that pline objects are shown as filled, are you saying that all your drawings existing and new have the variable set to (1)?
    Can you post an example drawing, one with expected behavior and one with unexpected behavior?
    Cheers!
    Volker
    Please let us know if your questions have been answered by selecting, "Accept as Solution"
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    09-21-2012 05:44 AM in reply to: Volker_C
    Attached is a DWG of an existing file with the issue.  Yes, FILLMODE is set to (1).
    I can't seem to find the new DWG that I had the issue with and I can't recreate the issue as any new DWG I start now does not seem to have this issue.
    My guess is that it has to do with specific drawings because other users have this issue with existing drawings too.
    Thanks.
    Product Support
    Volker_C
    09-21-2012 11:35 AM in reply to: KF090
    Thanks for supplying the drawing file try the following from the command line:
    Command: plan
    Enter an option [Current ucs/Ucs/World] <Current>: w
    Regenerating model.
    If this works please mark the solution as solved. Cheers!
    Volker
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    09-21-2012 11:38 AM in reply to: Volker_C
    That worked, thanks.
    Is there a known cause that we can try to avoid in the future?
    Product Support
    Volker_C
    09-21-2012 11:43 AM in reply to: KF090
    Sorry, I have looked and there is no known issue in regards to a product defect. It could be a start up LISP routine or third party application or user input. Wish I could give you a better answer.
    Cheers!
    Volker
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
