• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    PROBLEM 3D CONNEXION CONTROLLER BUT INTERFERES WITH AUTOCAD MECHANICAL
    218 Views, 12 Replies
    10-16-2011 05:38 PM
    OPERATING SYSTEM WIN 7 PRO 64 BIT, AUTODESK VERSION 2011 AND 2012 WHEN USING AUTOCAD MECHANICAL AND
    THE CONTROOLER IS TOUCHED I LOSE CURSOR AND DRAWING LINES BECOME ASKEW. THE ONLY WHY TO FIX THIS IF I CAN GET MY CURSOR BACK, IS TO TYPE PLAN AND THEN WORLD AND EVERYTHING GOES BACK TO NORMAL.
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: PROBLEM 3D CONNEXION CONTROLLER BUT INTERFERES WITH AUTOCAD MECHANICAL
    10-16-2011 09:27 PM in reply to: tdigiannurio
    I would suggest you to upgrade your mouse driver to the latest one from the 3D Connexion site.
    http://www.3dconnexion.com/service/technical-support.html
    If the problem persists, can you try this solution below as well.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14898223&linkID=9240617
    Hope it helps.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    SlowCad
    10-17-2011 01:02 AM in reply to: tdigiannurio
    We have this problem also. We have Win7 64-bit now, but when we had WinXP 32-bit the problem was there too.
    - updating driver doesn't help
    - the 'Plan', 'World'-trick doesn't help
    - enabling Hardware Accelarator doesn't help
    Gr. John
    Product Support
    10-17-2011 08:19 PM in reply to: SlowCad
    Did you manage to upgrade your graphic card driver. If not, you can download the certified ones from the link below,
    http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
    Please also check whether you have Windows Aero feature enabled for your OS. If so, can you turn it off and let me know the results.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Autodesk Support
    Autodesk, Inc.
    SlowCad
    10-17-2011 11:09 PM in reply to: tdigiannurio
    - turned 'Aero' off: no change
    - graphics driver updated: no change
    Like I mentioned: we used WinXP 32-bit (no 'Aero') and we had that problem also.
    John
    10-18-2011 08:03 AM in reply to: tdigiannurio
    I am using the required newest video driver suggested by autodesk for my operating system and Inventor version 2012. I feel this is not a video issue. A new problem has surfaced in version 2012 that i did not have in 2011, when i accidently touched the controller Autocad crashed, this has happened twice and has never happened in previous versions. So I feel it is a more serious issue and Autodesk needs to be serious about a solution to this problem . I know this because i called 3D connexion support and they told me that starting with 2011 Autodesk has told thnm that they will handle the driver for this controller in their own software. So 3D connexxion is not making drivers for Autocad products past 2010 version. It is coincidental that this is exactly when i started having this problem.
    Product Support
    10-18-2011 08:56 PM in reply to: tdigiannurio
    Hi Guys,
    Thanks for the update. Did you manage to submit a crash report, if so can you provide the email address you have used.
    As for as i know there was some issue with 3D connexion mouse which was addressed in Update 1 for AutoCAD.
    Did you install Update 1 on your machine. if not, you can download from the link below.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17809346&linkID=9240898
    Hope it helps.
    Autodesk Support
    Autodesk, Inc.
    SlowCad
    10-18-2011 11:15 PM in reply to: tdigiannurio
    AcadM does not crash, in our situation. It 's just that bij accidentally touching the controller, the drawing is not useable anymore (like tdigiannurio mentioned). By writing it to a wblock and then opening again, the drawing is useable again.
    Regards, John
    Product Support
    10-19-2011 12:14 AM in reply to: SlowCad
    Hi John,
    Can you test the solutions in the following thread and let me know whether it helps or not.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15127843&linkID=9240617
    http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2011-Cursor-Lag-issues-when-moving-objects/td-p/...
    Hope it helps.
    Autodesk Support
    Autodesk, Inc.
    SlowCad
    10-19-2011 12:33 AM in reply to: tdigiannurio
    Hi Vinod,
    Thanks for reply. Tried the things that are suggested. Nothing helps. Turning off virus scanner is not possible, because it's network controlled. It has nothing to do with performance. It would be a solution if we could turn off the controller in Acad, because we only use it in Inventor.
    John
