• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Distinguished Contributor
    Orientation of object changes when using xref "copy to working set"
    100 Views, 3 Replies
    02-17-2012 07:39 AM
    For some reason when I use copy to working set while editing an xref the orientation of the object goes haywire.  When I add the object, no problems.  I have to repeat this process roughly 400 times.  I either have to have an object copied 400x to add to each reference over and over again or I have to align each object after I add it to the xref.  It's enough of a pain to have to copy this to the xref but I've got a method that might speed things up which I can't use if I have to keep reorienting the objects.
    I'm using ACAD Mechanical 2011.
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Orientation of object changes when using xref "copy to working set&quot
    02-19-2012 06:42 PM in reply to: jpblower
    Can you share with us your drawing file and the exact steps to reproduce the problem. I will have a look into it as soon as i have them from you.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    02-20-2012 09:16 AM in reply to: jpblower
    I can't send the actual files but I'll see if I can send something representative that consistently gives me the same problems.  I thought it might be a ucs problem but I get the same results when I align and set to world.
    Product Support
    02-21-2012 05:58 PM in reply to: jpblower
    Are you looking for something similar to the one below,
    http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-Archive/Copying-objects-to-quot-REFEDIT-quot-w...
    Autodesk Support
    Autodesk, Inc.
