• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Insatlled AutoCAD Mech 2013, now I have no printers
    117 Views, 3 Replies
    04-30-2012 12:12 PM
    Installed 2013 mechanical and now I have no printers at all. Not even the ability to pdf. IT has no solutions. any help would be appreciated.
    Please use plain text.
    Employee
    Re: Insatlled AutoCAD Mech 2013, now I have no printers
    05-01-2012 08:06 PM in reply to: chemlite91
    Can you please let me know the detail on how you install the product and also your machine detail?
    You should be able to find plotters after run PLOTTERMANAGER command. It will open the plotters available.
    My machine is win7 64bit and default plotters are as below.
    C:\Users\xxx\AppData\Roaming\Autodesk\AutoCAD Mechanical 2013 - English\R19.0\enu\Plotters
    I have zipped the plot styles for reference.So you can use Add-A-Plotter Wizard to add plotters.
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    05-04-2012 06:16 AM in reply to: michaelsu
    Thanks for the help. after not being able to print for the past week, we repaired the software and that didn't work. it finally took re-installing 2013 two times for it to install correctly. i'm unsure what happened during the install, but at least in the end it fixed itself.
    once again thank you.
    Diana
    Employee
    05-07-2012 08:11 PM in reply to: chemlite91
    You are welcome.
    Glad your issue is resolved. :smileyhappy:
    Thanks.
    Michael Su
    SQA Engineer
