• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Mechanical
    Member
    damandeep.gujral
    FATAL ERROR
    182 Views, 5 Replies
    04-19-2012 10:44 PM
    I have installed Autodesk Inventor Professional Suite 2010 on Windows 7 64 bit machine. Inventor is running properly but I do get message FATAL ERROR: Unhandled Access Violation Reading 0x40f2d180 Exception at 31f365bdh when I draw a line in model space and select the line.
    Can anyone give me some solution on how to fix this problem.
    Please use plain text.
    Employee
    Re: FATAL ERROR
    04-20-2012 12:30 AM in reply to: damandeep.gujral
    Did you patch the latest service patch for your product? Also, did you fill in the report dialog with your email and steps?
    AutoCAD Mechanical 2010 Update 2 is here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15135668&linkID=9240898
    If it's constantly reproducible, can you please send your drawing and reproducible steps to zhiyuan.su@autodesk.com?
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    Member
    damandeep.gujral
    Re: FATAL ERROR
    04-22-2012 03:48 PM in reply to: michaelsu
    There is no particular drawing. When we launch AutoCAD, AutoCAD Mechanical, AutoCAD Electrical it opens a new drawing by default   which is named as Drawing 1. Select Line command and draw a line. Press escape to finish command and when we drag cursor from right to left to select everything in the window it shows the grips of the object selected and in next 1 or 2 seconds a window pops up which is for sending a report to Autodesk.
    Employee
    Re: FATAL ERROR
    04-22-2012 07:27 PM in reply to: damandeep.gujral
    Did you send your report and fill in your email address? Can you let me know your email address so I can search it in the report list?
    Also, I tried your steps after launch AutoCAD and AutoCAD Mechanical but could not see the crash. If you just launch one product, do you see the issue? Can you persistently reproduce this issue?
    Thanks.
    Michael Su
    SQA Engineer
    Member
    damandeep.gujral
    Re: FATAL ERROR
    04-22-2012 07:36 PM in reply to: damandeep.gujral
    I have submitted the error report with damandeep.gujral@normet.fi.
    Does not make any difference if you have opened just one or all  three Autocad, Autocad mechanical and autocad electrical.
    Employee
    Re: FATAL ERROR
    04-23-2012 02:58 AM in reply to: damandeep.gujral
    Hi
    I have searched the report and found it's not a general issue. Does it happen to other machines? Can you try to re-install the product and see whether the issue goes away?
    Thanks.
    Michael Su
    SQA Engineer
