• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    Bsmall
    Escape key not working in 2011 Autocad Mechanical
    3242 Views, 6 Replies
    10-26-2010 05:15 AM
    Hello Everyone,
    I have recently upgraded to Autocad 2011 Mechanical and I have noticed that when I select a line, block, or solid and I try to deselect it by hitting escape.  It will not deselect the object.  I did find on another thread that this has happened on Autocad 2011 MAP 3-D program and that there was a hotfix.  However, I do not think that hotfix applies to Autocad 2011 Mechanical.
    Is this a known issue and is there a fix for it?  Thanks in advance for the time.
    EDIT:  I have tried the PICKFIRST command as well and it did not work either.
    Please use plain text.
    *Pro
    Re: Escape key not working in 2011 Autocad Mechanical
    10-26-2010 06:32 AM in reply to: Bsmall
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
    I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
    Member
    Bsmall
    10-26-2010 06:37 AM in reply to: Bsmall
    Thanks for the reply, but based on your response I am assuming I should post my question on that forum?  I searched that forum for my problem and did not find anything that matched it.
    SlowCad
    10-27-2010 01:20 AM in reply to: Bsmall
    Maybe it's got something to do with SP1, because it's one of the issue's mentioned here:
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/Autocad-Mechanical-2011-problems-after-installing-U...
    Try uninstalling SP1 and see if this helps.
    Distinguished Contributor
    11-03-2010 08:05 PM in reply to: SlowCad
    I am having the same issue. Installed from the Inventor 2011 Professional discs.
    Anyone come up with a fix yet?
    Inventor Professional 2013.
    Windows 7 64 bit.
    11-22-2010 01:16 PM in reply to: Bsmall
    same problem, only I have been running 2011 for months and it just started happening today.
    *edit* restart Autocad and I'm back to normal (well, the esc key is back to normal, anyway...)
    02-28-2012 01:13 AM in reply to: thomasjlandry
    Re-install the ATI video driver software. http://forums.adobe.com/message/2977659
    Kind regards,
    Peter Kompier.
