• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Active Member
    tuomas.takkinen
    Error while plotting PDF
    665 Views, 5 Replies
    11-09-2011 02:36 AM
    Hi all,
    I'm facing randomly problem while plotting dwg -files to pdf. For example I have four dwg-files, and one of them gives to me following error message:
     Job: - Error(s) Did Not Plot
    Job ID: 1
    Sheet set name:
    Date and time started: 9.11.2011 12:28:13
    Date and time completed: 9.11.2011 12:28:13
    UserID: tuomas.takkinen
    Profile ID:
    Total sheets: 0
    Sheets plotted: 0
    Number of errors: 0
    Number of warnings: 0
    ERROR: There were no plottable sheets in the current operation.
    This is not very common problem, I have approx only five of dwgs which I cannot plot to pdf because of this. Is there any solution to this problem? Thanks in advance
    Please use plain text.
    Valued Contributor
    Re: Error while plotting PDF
    04-18-2012 07:37 AM in reply to: tuomas.takkinen
    Did you find a solution?
    Employee
    04-18-2012 08:05 PM in reply to: tuomas.takkinen
    Are you still facing this problem at work?
    Did you try to plot or exportpdf for the problematic drawing alone?  Have you checked whether the problematic drawing has a plottable sheet or not?
    If you still have such problem, can you please send me the drawings for a closer look?
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    New Member
    05-04-2012 12:52 AM in reply to: tuomas.takkinen
    Nope, but I'm facing this problem very randomly, but today I found .dwg I which I cannot plot. It has the same error message. Please find the enclosed attachemnt
    Job ID: 3
    Sheet set name:
    Date and time started: 4.5.2012 10:35:45
    Date and time completed: 4.5.2012 10:35:45
    Profile ID:
    Total sheets: 0
    Sheets plotted: 0
    Number of errors: 0
    Job ID: 1
    Sheet set name:
    Date and time started: 4.5.2012 10:32:43
    Date and time completed: 4.5.2012 10:32:43
    Profile ID:
    Total sheets: 0
    Sheets plotted: 0
    Number of errors: 0
    Employee
    05-07-2012 07:53 PM in reply to: tuomas.takkinen
    I found the attached drawing has “Layout not initialized” for model space and paper space in Public dialog if you try PUBLISH command. That's why it gives an error about "There were no plottable sheets in the current operation."
    The workaround is to invoke plot dialog once and close it. Then you should be able to do the export operation without errors.
    Thanks.
    Michael Su
    SQA Engineer
    New Member
    05-07-2012 10:20 PM in reply to: michaelsu
    Michael, thank you very much! That workaroun solved the problem!
