• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Valued Contributor
    Mike686
    Accepted Solution
    EXPRESS TOOLS don't work
    4732 Views, 9 Replies
    04-03-2011 05:32 PM
    hi, i install the express tool after i installed autocad mechanical 2011 and the menu is there but none of the commands like auto text numeribg and explode attributes to text,  works..
    any ideas why?
    Product Design Suite 2013
    Please use plain text.
    Employee
    Re: EXPRESS TOOLS don't work
    04-04-2011 07:16 PM in reply to: Mike686
    Try following steps and verify if it works.
    Step 1 >> CUILOAD the cui file “acetmain.cuix”>>Express Tool panel is listed in the ribbon
    Step 2 >> APPLOAD 2 FAS files(acettest.fas and acetutil.fas) from the express menu, refer to the image attached.
    Let me know if this helps
    Sridhar Subramani
    Autodesk, Inc.
    Valued Contributor
    Mike686
    Re : EXPRESS TOOLS don't work
    04-16-2011 12:24 PM in reply to: Mike686
    i try to do what you said but when i try to load the application, theres no .fas listed in the express folder...
    Employee
    04-17-2011 07:16 PM in reply to: Mike686
    Please try suggestion in the following thread first, then followed by my previous suggestion to load the *.fas files.
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/adding-express-tools-menu-after-installation/m-p/26...
    Sridhar Subramani
    Autodesk, Inc.
    Valued Contributor
    Mike686
    04-21-2011 12:13 PM in reply to: Sridhar-Autodesk
    i have repair the product a second time and now its seem to work fine
    thanks again
    Active Member
    09-30-2011 04:11 AM in reply to: Mike686
    I had the same problem express tools didn't work even after reinstalling.
    After installing SP1 the problem still existed.
    Loading the fas files was for me the solution, now all funtions work as they should.
    Problem solved.
    :smileyvery-happy:
    New Member
    rmalouff
    03-05-2012 10:28 AM in reply to: Sridhar-Autodesk
    Structure 2012
    I went through the steps of unloading a reloading Express tools, and then the steps metioned above and had txt2mtxt working.  Now it does not work.
    I went through the steps mentioned above and now get:
    "Unable to load customization file:
    That Customization Group already exist."
    Didn't we pay to have the programming for this package completed by Autodesk?
    Active Contributor
    11-19-2012 12:14 PM in reply to: rmalouff
    have the same problem,,,load the two .fas files,,,corrected the problem in the working drawing only,,will not auto re-load on new drawing,,,have to appload everytime..??
    Employee
    11-19-2012 04:47 PM in reply to: jedenton
    You may try to add them to "Startup suite"
    Command: Appload>>Contents>>Add>>Browse and add both files
    Hope this helps,
    Sridhar Subramani
    Autodesk, Inc.
    Member
    02-20-2013 09:20 AM in reply to: Sridhar-Autodesk
    AutoCAD Architecture 2013 Building Design Suite, I'm having the same problem of "Convert to Mtext" not working. I've tried the APPLOAD> process several times without success, it remains "txt2mtxt Unknown command". And I couldn't access AutoCAD through Win7 Control Panel>Programs. Any other suggestions? Thank you in advance.
