• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Active Member
    Accepted Solution
    Dynamic blocks grip/basepoint problem
    308 Views, 7 Replies
    10-31-2012 06:47 AM
    I have a dynamic block with several actions and parameters. If i insert or paste this block near my template, the X/Y basepoint stays near the template when i drag the block on the template with one of the other two grips.. When i print the drawing the basepoint stays visible.
    How can i solve this problem?
    Kind regards,
    Stefan de Rond
    Autocad dummy :smileyhappy:
    Please use plain text.
    Employee
    Re: Dynamic blocks grip/basepoint problem
    10-31-2012 08:57 PM in reply to: stefanderond
    Hello Stefan,
    Could you please also attach your sample for further look?
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    Active Member
    11-01-2012 12:52 AM in reply to: stefanderond
    Here is the .dwg file.
    Kind regards,
    Stefan de Rond
    11-01-2012 10:19 AM in reply to: stefanderond
    See if this works for you?
    Active Member
    11-07-2012 03:41 AM in reply to: stefanderond
    Sorry, the problem still exists.
    The X/Y basepoint is still not fixed/locked at the block himself.
    Thanks for trying.
    Kind regards,
    Stefan de Rond
    Autocad dummy:smileyhappy:
    Employee
    11-07-2012 06:30 PM in reply to: stefanderond
    Hi Stefan,
    I take a look the block and find two points objects in the block. Are they the base points you refer to? I think you can use Geometry constraint to fix them if you really need them.
    If not, you can just remove them and save the block. So the points won't appear in your plot. Please see if it is working as you expect.
    Thanks.
    Michael Su
    SQA Engineer
    Active Member
    11-07-2012 11:40 PM in reply to: stefanderond
    No there is a third grip point, but you can only see him when you move one of the other two points.
    Removing the other two points is not an option. I need these points to move the block. The third point may be removed or fixed at the block himself, but i dont know how to do that.
    Kind regards,
    Stefan de Rond
    Autocad Dummy :smileyhappy:
    11-20-2012 10:10 AM in reply to: stefanderond
    Hi Stefan
    After playing around for a while and making my own version of your block I finally noticed your stretch frame for the text/balloon was a polyline or something. I changed it to a rectangle and and now the dot nolonger appears so hopefully it is fixed and behaves how you need it to.
    I changed that stretch frame and added a basepoint parameter that moves with the arrows position/stretch action.
    I made my own block to see if replicating your block would give me the same issue and it didn't, but I went a bit further with the dynamics of mine. I have attached it incase it is of any use to you however the arrow dosnt move independently of the Block as yours does.
    Chris.
