• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    Convert DWG to IGES
    4676 Views, 17 Replies
    01-19-2010 02:08 PM
    I have a DWG file that I need to convert to a IGES. Is there anyone that can do this for me? I do not have AutoCad nor do I know how to use it, so any help will be much help. Thanks Lonnie
    Please use plain text.
    *Dennis Jeffrey
    Re: Convert DWG to IGES
    01-19-2010 08:28 PM in reply to: lawharrell
    You will need AutoCAD Mechanical at a minimum, MDT or Inventor will
    generate NURBS curves which will be more accurate. Can you zip and post
    the file (under 1.5MB) here?
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Attend the "It's a Duesy II " Manufacturing Revival Conference
    March 17th, 2010 More Information at:
    http://teknigroup.com
    Member
    01-20-2010 05:52 PM in reply to: lawharrell
    Thanks for the reply Dennis. I attached the file and zipped it. I hope you can make this happen. Thank you in advance.
    Lonnie
    Employee
    01-21-2010 06:59 PM in reply to: lawharrell
    Lonnie,
    Find attached zip file containing 2 igs file. One translated using Surfaces and the other as NURBS Surfaces.
    Sridhar
    Sridhar Subramani
    Autodesk, Inc.
    Member
    01-23-2010 09:42 AM in reply to: lawharrell
    Sridhar,
    Thank you for your time and effort.
    Lonnie
    New Member
    02-02-2010 10:23 AM in reply to: lawharrell
    I have a DWG file that I need converted to IGES but it is too large to post here. Could someone please help me.
    *Expert Elite*
    02-02-2010 11:58 AM in reply to: lawharrell
    I'm not positive but I think free Inventor Fusion will do the conversion http://labs.autodesk.com
    The file size limit is much larger over here http://www.augi.com
    Member
    kedar_til
    06-08-2010 07:16 AM in reply to: lawharrell
    Can someone help me to convert this .DWG file to IGES? It is required for machining on VMC.
    - Kedar
    New Member
    sid1988
    08-14-2010 01:46 AM in reply to: Sridhar-Autodesk
    Heyy lonnie / Shridhar
                                         Can you please convert the .dwg file to .iges please..
     I have also attached the file..
    thanking you in advance
    regards/siddharth
    New Member
    sid1988
    08-14-2010 01:52 AM in reply to: Sridhar-Autodesk
    Heey every one ..please help to convert the below file attacted in .dwg format into .iges format.
    please i am urgent need..
    regards/siddharth
