• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    Autodesk SymBBAuto 3.0 Type Library
    588 Views, 5 Replies
    08-12-2010 08:48 AM
    Have a big problem with Autocad Mechanical 2011 VBA.
    I get a Runtime error (Problem in  loading application.)
    Here is the code:
    Dim symbb As McadSymbolBBMgr
    Set symbb = Thisdrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
    The SymBBAuto fails to load. Has anyone have the same problem?
    Looking for any comments and/or fixes on this problem in Autodesk SymBBAuto 3.0 Type Library.
    Please use plain text.
    Active Contributor
    Re: Autodesk SymBBAuto 3.0 Type Library
    05-03-2012 06:02 AM in reply to: mastertool
    I've got the same problem with AM 2013.
    Active Member
    07-12-2012 09:33 AM in reply to: FRFR1426
    did you solve this problem?
    Please see
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/SymBBAuto-x-ACADM-2013-VBA/td-p/3536186
    I have the same issue...
    Active Contributor
    07-12-2012 11:59 PM in reply to: mastertool
    Yes, I've solved my problem, but unfortunately I don't remember how and I'm not able to find something about that in my notes.
    But in my final code, I'm using :
    Dim symMgr As New McadSymbolBBMgr
    instead of :
    I'm using Interop.SymBBAuto 3.0 with Embed Interop Types at true and Isolate at false.
    Also if you want to run your app on x86 and x64, you have to change the guid of the reference in your .vbproj file :
    {71477CDD-CA02-4842-98C7-7141520E7D70} for x64
    and
    {4A193255-4AC6-4E04-9DE7-B041C5B216D4} for x86
    It is a misery, as always with COM...
    Employee
    07-13-2012 01:53 AM in reply to: FRFR1426
    FRFR1426:
    please read my reply in
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/S​ymBBAuto-x-ACADM-2013-VBA/td-p/3536186
    it might help you.
    Li Fei
    SQA Engineer
    Active Member
    07-13-2012 12:22 PM in reply to: FRFR1426
    hi FRFR1426
    Many thanks for your tip.
    I tried also the tip from Li Fei and it worked very well on ACADM 2013 ! But some other conversions were needed, now we are able to migrate.
    Regards
