• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    crobson
    Autocad Mechancial 2012 will not show the hatch on previously saved file
    166 Views, 3 Replies
    02-29-2012 06:29 AM
    When I open a file that my coworkers have previously saved the hatch in some of the blocks disapeare. However when I open up the blocks in the block editor the hatch is still there. How do I fix this?
    Please use plain text.
    Product Support
    emily.xu
    Re: Autocad Mechancial 2012 will not show the hatch on previously saved file
    03-01-2012 08:24 PM in reply to: crobson
    Could you please attach some sample files to do some research? Thanks
    Emily Xu
    AutodeskCare | Product Support
    Product Support
    emily.xu
    03-01-2012 09:02 PM in reply to: crobson
    Or try to set the system variable Fillmode=1,then regen your drawing, see if works.
    Emily Xu
    Product Support
    emily.xu
    03-04-2012 07:15 PM in reply to: emily.xu
    Do you have any update for this issue?
    Emily Xu
