• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Distinguished Contributor
    Talayoe
    AutoCad Mech. Crashing
    251 Views, 6 Replies
    04-28-2012 07:18 AM
    Good morning,
    I am now running 2013, hoping that my problem would have been resolved on its own with the upgrade...apparently not.
    Starting from 2012, when I exit a file, NOT the program (so, hit the X on the individual drawing window or hit the bit 'A' and close) my Mechanical crashes giving me these errors. It is not consistent but it is frequent. It scares me to close files individually for fear of a program crash. Then when I start up I get that stupid recovery manager.
    This has forced me to be more diligent in saving my work before doing anything, but that is not the point. Why would my program(s) be crashing like this? Any ideas?
    TIA!
    Inventor 2013 PDS
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: AutoCad Mech. Crashing
    05-01-2012 05:56 PM in reply to: Talayoe
    Do you see this error while working on a particular drawing or closing any drawing file.
    Have you tried doing a repair install of the product.
    If the problem is specific to a particular drawing, can you provide us to test further.
    Looking forward to your updates.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Talayoe
    05-01-2012 08:44 PM in reply to: VinodBalasubramanian
    Good evening,
    This happens on (frequent) random drawings. it may happen on the same drawing but only by chance the way it seems.
    The repair I have not done. How is this accomplished?
    Thanks! :smileyhappy:
    Inventor 2013 PDS
    Product Support
    05-01-2012 09:46 PM in reply to: Talayoe
    You can follow the steps below to do a repair install,
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
    Do let me know, if the problem persists after that.
    Autodesk Support
    Autodesk, Inc.
    05-02-2012 06:48 AM in reply to: Talayoe
    Hi TIA,
    I have been having the same problem with ACADM2K12 & ACADM2K13 for months.
    It look like It is how you close the program.
    I now close from the tool bar.
    donb
    donb
    Product Support
    05-02-2012 05:41 PM in reply to: donb
    Once it crashes, it will create a crash report. Can you try submitting it and provide us the email address you have used.
    Can you also confirm whether you have installed all the service packs for AutoCAD Mechanical.
    Please provide us the following information for us to troubleshoot.
    Go to Start -> Run -> %temp% -> Look for any error logs for AutoCAD with .log extension.
    Also send us the system info and windows event logs,
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7491145&linkID=9240617
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7491149&linkID=9240617
    Autodesk Support
    Autodesk, Inc.
    Talayoe
    05-02-2012 08:11 PM in reply to: VinodBalasubramanian
    I ran the repair tool and have yet to have a crash. This is not to say it has resolved the issue as I can go days without a crash, but we will see given time.
    As for the crash reports, it does not generate these. I have seen Autocad generate these before and ask to be emailed in, but the way this fails it doesnt generate making me think it may be more of a windows conflict with Autocad? Just shooting out ideas. The two screen shots I posted above are literally all I get. First the top screen shot, then when that processes I get the bottom one and that is all.
    Also, I would question the service pack idea as Acad 2013 Mech just premiered a few weeks ago...? Honestly I can say I havent checked but only because it is so new I suppose I figured there shouldnt be any yet. I will check on this tomorrow at work.
    I will check the rest of the details at work tomorrow and report back.
    Thanks for keeping this going!
    Inventor 2013 PDS
