• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Active Member
    AutoCAD and Windows 8 Consumer Preview
    13912 Views, 14 Replies
    04-25-2012 05:15 AM
    I was trying to install AutoCAD Mechanical 2012 x64 on my Windows 8 CP x64. but the installer couldn't install .NET 4.0, as it is in-built in WIndows 8, and the setup failed. I edited the setup.ini file to exclude DOTNET4 from all the components' prerequisites and then the AutoCAD installed fine.
    then, after launching the program, working and then upon closing, I was getting the famous 'unhandled access violation error', followed by a "send error report to Autodesk" with my AutoCAD Mechanical 2012 x64 on Windows 8 Consumer Preview x64. however after much searching on the net i found the following solution to be helpful:
    1. open Notepad as Administrator (important!)
    2. open the file: "C:\Program Files\Autodesk\AutoCAD 2012\acad.exe.config" (you will have to select "All files" from the open dialog box to see that file)
    3. in the 3rd line - "<startup useLegacyV2RuntimeActivationPolicy="true">" change "true" to "false". leave everything else as it is.
    4. save the file.
    5. Start AutoCAD.
    the AutoCAD then worked absolutely fine.
    Now, I'm getting the same problem in AutoCAD Mechanical 2013 x64 and the same steps are not helping...at all!
    the installation went absolutely fine without the need to edit setup.ini this time. But this bug won't go now.
    Can anyone help me to remove this bug? I know Windows 8 is not officially supported by AutoCAD but well, it worked fine and it should work fine now! any genius coder out there??
    Please use plain text.
    New Member
    Re: AutoCAD and Windows 8 Consumer Preview
    06-10-2012 11:17 PM in reply to: sarim_xyz
    Getting the same kind of issue bro :/
    Active Member
    Re: AutoCAD and Windows 8 Release Preview
    06-11-2012 02:17 AM in reply to: damianemuller
    I even tried installing in Windows 8 Release Preview, but same error. I wonder what is taking so long for Autodesk to come up with the Windows 8 support. They should issue some fix for Windosw 8 asap, it's high time now!!
    Valued Contributor
    06-11-2012 06:48 AM in reply to: sarim_xyz
    It is my experience with AutoDesk that they will not fix bugs in Windows versions until it is released to the public and out of beta (preview) stage.
    Autocad Mechincal 2012 on Windows 7 64-bit
    Active Member
    06-17-2012 07:24 AM in reply to: wolfgrrl
    that's stupid...nvidia has already been releasing drivers for Windows 8 even since Developer Preview came out. now how can i use autocad 2013? huhh...m not going back to Windows 7!
    New Member
    joep
    06-25-2012 03:01 AM in reply to: sarim_xyz
    I had the same problem on Windows 8 Release Preview.
    The .config-edit made AutoCAD crash even faster - about half a second after showing the spash screen.
    Just setting compatibility mode for AutoCAD 2013 to Windows 7 compatilibility solved it for me.
    Active Member
    08-07-2012 04:43 AM in reply to: joep
    still crashing :smileysad:
    *Expert Elite*
    pendean
    08-08-2012 05:57 AM in reply to: sarim_xyz
    Search these forums outside of this one single discussion area for tips, many of us have it working just fine.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    New Member
    11-17-2012 04:04 AM in reply to: sarim_xyz
    Only seems to be a combatibility problem with new computers running Windows 8 and AutoCAD 2012. Export your licence prior to installing Windows 8 and import it to get going again when Windows 8 has been installed.
    New Member
    11-18-2012 06:34 AM in reply to: sarim_xyz
     "I edited the setup.ini file to exclude DOTNET4 from all the components' prerequisites and then the AutoCAD installed fine."
    I can't understand how to install autocad 2012 in window 8 release preview and what mean of red letters highlight above. would you please tell me clearly or step by step procedure
