• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Active Member
    Accepted Solution
    AutoCAD Mechanical in "DOS" mode
    367 Views, 5 Replies
    12-27-2012 07:52 PM
    I'm using AutoCAD Mechanical 2013. I attempted to open igs & stp files with Inventor Fusion. The result, many common used functions in Mechanical has become DOS mode.
    Eg. When I key in saveas, it will prompt me on the command line to sellect which version, then key in the entire path of the new file to be kept.
    Can some experts share how to resolve it? MTIA:smileysad:
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: AutoCAD Mechanical in "DOS" mode
    12-28-2012 06:11 AM in reply to: elaine.chan
    fileDia  press enter then type in 1
    try typing that into the command line
    Active Member
    01-01-2013 06:25 PM in reply to: elaine.chan
    You're a god sent! Issue resolved! Thanks a million!
    Can share what the problem was? Wanna learn more....
    Active Member
    01-06-2013 04:54 PM in reply to: DarrenP
    Another issue: I can't open the Layer manager dialog box :smileyindifferent:
    It prompted me to enter Layer/Object keys
    Valued Contributor
    01-07-2013 01:24 PM in reply to: elaine.chan
    Type CMDDIA and set it equal to 1.
    -Autodesk Inventor Professional 2012
    Active Member
    01-15-2013 06:07 PM in reply to: nannerdw
    A million thank you! Regards Elaine
    Edited by
    Discussion_Admin
