• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    tomjames3d
    AutoCAD Mechanical AMREVLINE behavior
    248 Views, 5 Replies
    06-23-2011 12:36 PM
    I am setting up a standards DWT file and require:
    • 4 different borders (A,B,C,D size)
    • 4 different titleblocks (A,B,C,D size)
    • 2 different revision block types (A size, all others)
    The problem is that when I add a line to the revision via AMREVLINE there seems to be 4 ways of doing so and each yields different results.
    Start the AMREVLINE command then:
    1. press enter for global
    2. select the border
    3. select the titleblock
    4. select one of the previous lines
    The behavior is different for each of the different layouts I create via AMTITLE.
    test one: no selection on initial insertion (global)
              none     border     titleblock     revline
    a          new     new          new          new
    b          new     adds          adds          new
    c          adds     new          new          adds
    d          adds     new          new          adds
    test two: border selection on initial insertion
    same results as above
    The new revision row will either be added to the prior list or create a new one.
    What are the rules of AMREVLINE row addition?
    TomPy
    Please use plain text.
    Employee
    Re: AutoCAD Mechanical AMREVLINE behavior
    06-23-2011 08:36 PM in reply to: tomjames3d
    Global Space will insert a new revline always.  Whereas Border/Titleblock will add a revline to the last inserted revline.
    Please see below example.
    Scenario-1
    1. Insert a revline using Global (P1)
    2. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-1
    Scenario-2
    1. Insert a revline using Global (arbitrary P1)
    2. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-1 (will add to P1)
    3. Insert a revline using Global (arbitrary P2)
    4. amrevline>>Select Border/Titleblock>>will add to the revline inserted in step-3 (will add to P2)
    Therefore use Global option only when you insert a revline for the first time.  Thereafter, I would suggest you to use Border/Titleblock option to add subsequent revlines.
    Hope this helps
    Sridhar Subramani
    tomjames3d
    07-05-2011 10:15 AM in reply to: Sridhar-Autodesk
    In your Scenario-1, two of my four sizes are working as you suggest and two are not.
    C & D sizes are working perfectly.
    However, the A & B sizes are not.
    I did a further test using the following:
    D Titleblock with B Border = Works as you have described
    B Titleblock with D Border = Works as you have described
    A Titleblock with D Border = Works as you have described
    D Titleblock with A Border = Works as you have described
    But
    B Titleblock with B Border = just keeps adding new revline sets
    A Titleblock with A Border = just keeps adding new revline sets
    My method for the test was:
    1. start a new file
    2. AMTITLE (selecting the appropriate border/titleblock)
    3. AMREVLINE (hitting 'return' for global space, type in a revision number, place the revision line set via snapping to a titleblock line)
    4. AMREVLINE (selecting the previously added Revision line, typing in the next revision number)
    Any ideas why I could be seeing this behaviour?
    TomPy
    Employee
    07-06-2011 07:24 PM in reply to: tomjames3d
    In your method of test, on step 3 and 4, can you always select Border (instead of Global) and verify if it adds a revline to previous one?
    Sridhar Subramani
    tomjames3d
    07-28-2011 04:33 PM in reply to: Sridhar-Autodesk
    The issue is that the behaviour is different for C and D sizes. What is the issue with the different behaviour for the different sizes?
    I am very tired of chasing this issue in circles. can I send someone a data set and have thenm just solve it?
    Tom
    Employee
    07-28-2011 07:31 PM in reply to: tomjames3d
    Can you zip and attach the file to this thread or send them at sridharDOTsubramaniATautodeskDOTcom
    Also let me know AutoCAD Mechanical version and operating system.
    Sridhar Subramani
