• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    New Member
    AutoCAD Mechanical 2013 and short cuts
    234 Views, 2 Replies
    06-15-2012 12:12 AM
    I'm using AutoCAD Mechanical a long time and now I changed to AutoCAD Mechanical 2013. There, I can't use any longer the short cuts, which are shown inside the acad.pgp. Is there a switch, where I can activate the short cuts again.
    Christoph
    Please use plain text.
    New Member
    massimiliano.pani
    Re: AutoCAD Mechanical 2013 and short cuts
    07-05-2012 06:31 AM in reply to: christoph
    uses the file version 2012, works
    Max
    Employee
    07-05-2012 08:54 PM in reply to: christoph
    Hello Christoph,
    Have you used the Reinit command? That will reload your pgp file while your in Autocad. Along with closing Autocad and reopening it.
    Are you using the AutoCAD pgp file under the support folder?
    You can find your pgp filepath by type
    (findfile "acad.pgp")
    You can create your commands by opening the PGP file and putting them under the –User Defined Command Aliases. Make sure there are no duplicates with the existing ones.
    Hope it helps.
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
