• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Valued Contributor
    AutoCAD Mechanical 2012 changes current dim style on its own
    800 Views, 1 Replies
    10-03-2011 09:07 AM
    The current dim style in AutoCAD Mechanical 2012 is frequently changing to "AM_ANSI" on its own for no apparent reason whatsoever.
    Sometimes it does this on a fresh startup, other times it will do it in the middle of my typical drawing routine.  There seems to be no particular commands or actions that cause it to do this.  On some days the current dim style will change once or twice, while on other days I'm dealing with it almost hourly.
    Any ideas on how to get AutoCAD Mechanical 2012 to stop doing this would be appreciated.
    Pete
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: AutoCAD Mechanical 2012 changes current dim style on its own
    10-03-2011 05:41 PM in reply to: pete592
    The thread below has answers to your query. It is applicable for 2012 release as well.
    http://forums.autodesk.com/t5/AutoCAD-Mechanical/2009-Mechanical-Dimension-Style-changes-to-AM-ANSI/...
    Hope it helps.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
