• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Member
    AutoCAD Mechanical 2012 Grid Display Settings and contentlib.xml file
    1117 Views, 3 Replies
    03-20-2012 11:06 AM
    Does anyone know how to keep the grid display turned off when opening up the program each time?  I just went from AutoCAD Mechanicl 2010 on a Windows XP 32 bit OS to AutoCAD Mechanical 2012 on a Windos 7 64 bit OS.  Everytime i open AutoCAD the grid disply is on....it wont stay turned off.  Also everytime i start up AutoCAD i get this error message sying it can't find the "contentlib.xml" file in the location under Document and settings.....\Gdb.  it is looking for the 2011 version of this file.  I t already has the 2012 version of this file.  Does anyone know how to direct it to look at the 2012 version and ignore the 2011.  I have never had earlier versions of AutoCAD intalled on this machine, so don't know why it is looking for and older file.
    Please use plain text.
    Product Support
    Matt.Desfosses
    Re: AutoCAD Mechanical 2012 Grid Display Settings and contentlib.xml file
    03-23-2012 07:50 AM in reply to: gojo
    The grid is controlled through your template file (.DWT).  If you open up your template file and turn the grid off and then save the template file the next time you launch that template the grid will be off.
    Matt Desfosses
    Support Specialist
    Product Support
    Employee
    03-27-2012 02:42 AM in reply to: gojo
    You may modify the contentlib.xml location using following steps:
    1. Command amcontentmanager
    2. Click on File Locations Button
    3. Click the ... button and point to the default location shown in the attached image.
    4. Click Save and Close button
    5. Close AutoCAD Mechanical and Relaunch and verify the issue.
    Sridhar Subramani
    Member
    03-27-2012 07:58 AM in reply to: gojo
    Sridhar Subramani,
    That worked perfect.  thank you very much.
