• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    TITOPERON4108
    AutoCAD Mech 2012 and 2013 corrupted files
    292 Views, 2 Replies
    05-07-2012 11:26 AM
    I have 2 files attached that I can not recover within Autocad Mechanical. I have already tried on AutoCAD Mechanical 2012 and 2013, but both showed me the same issues:
    "01505770 crash 19-04-2012.dwg" >> this file crashed AutoCAD imediately when openning
    "01505770 CANNOT ADD DIMENSIONS AND COPYCLIP CONTENT.dwg" >> this file does not allow dimension creation, copyclip (CTRL+C) and I cannot correctly insert correct parts list with filter by part on some layouts.
    Please someone could check this out?
    Dimitri
    Please use plain text.
    Product Support
    Matt.Desfosses
    Re: AutoCAD Mech 2012 and 2013 corrupted files
    05-14-2012 06:45 AM in reply to: TITOPERON4108
    The file that you could not put any dimensions in was corrupt in the template.  Once I inserted it into a new template I was able to put dimensions.  The other file I was not able to recover.
    Matt Desfosses
    Support Specialist
    Product Support
    TITOPERON4108
    05-17-2012 05:53 AM in reply to: Matt.Desfosses
    Thanks Matt,
    Yes, it is an abnormal situation that I would like Autodesk to avoid. The software cannot crash if the file is corrupted and the commands should work even if it is corrupted. Specially if you see simpler applications like Intelicad opening these files and operating them without any problem.
    I would like to hear from Autodesk if it is going to be fixed some day.
    Regards
