• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    New Member
    krissup
    AutoCAD Mech 2010 will not start - just seeing the p[lash screen
    172 Views, 1 Replies
    08-24-2011 08:28 AM
    I have a Dell M6500 computer using autodesk mech 2010 with a lic server server.  When click on the the autodesk 2010x64 icon I just get the flash screen for a second and it goes back to the program icon.  I tried on and off the network with the sam eresult.  I also tried installing the 2010 update 1 & 2 and it tells me it can't find the software to do the update.  I see the dir with the files on the the C: drive. any thoughts?
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: AutoCAD Mech 2010 will not start - just seeing the p[lash screen
    09-21-2011 07:40 PM in reply to: krissup
    What version of OS you have ?
    Can you turn off any anitivirus that's running on your machine. You can use the following solution to turn it off temporarily for testing.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7313059&linkID=9242018
    If you are using Windows 7 or Vista, can you go to Control Panel -> user accounts -> Change User account control settings and turn off UAC. Then test launching your AutoCAD Mechanical.
    Sometimes profile corruption can cause such problems. Try creating a new user login in Windows with local administrator rights and launch the software in that login.
    Hope it helps.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
