• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    Valued Contributor
    AMtext7 Settings
    241 Views, 4 Replies
    09-29-2008 05:59 AM
    Hello!
    Is there a way to change the default styles of
    AMtext3.5
    AMtext5
    AMtext7
    or this is hard coded?
    For example 7 to become 6?
    Please use plain text.
    Employee
    Re: AMtext7 Settings
    09-29-2008 08:48 PM in reply to: npet
    The text style is hard-coded into AMTEXT7, 5 etc commands. Thus you would have to customize own toolbars with the following macro in order to get the custom text heights.
    ^C^Cmtext;\h;6;
    ^C^Cmtext;\h;4;
    Sridhar
    Software QA Engineer
    Manufacturing Solutions Division
    Autodesk, Inc.
    Sridhar Subramani
    Autodesk, Inc.
    Valued Contributor
    10-07-2008 01:38 AM in reply to: npet
    We need the functionality of AMText commands, which most valuable is that recognizes the scale area.
    Why all companies have to work with textsize 7,5,3.5?
    Pls, take care.
    Thank you!
    Fotis
    Valued Contributor
    Pls, take care.
    Thank you!
    Fotis
    New Member
    10-08-2008 09:27 PM in reply to: npet
    AMTEXT commands are provided as utilities for quick access to the most common text height creation. Why these 3 (3.5, 5, and 7) are chosen is because they represent 3 typical text objects defined in Object Property Settings (AMOPTIONS->AM:smileyfrustrated:tandards) that controlling layer, color, linetype and lineweight. BTW, you can change the text height during the command.
    If you're looking for something more flexible, AMNOTE is probably the closest. It has a leader but can be turned off, and it works like any other Mechanical symbol text, react to scale area changes. If this still doesn't meet your requirement, can you send me an email at yun.liu@autodesk.com for more discussion?
    Liu Yun
    Developer
    Manufacturing Solution Division
    Autodesk, Inc.
