Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have Autocad Mechanical 2013 installed in my machine. Whenever I have the properties palette open and select an object, the properties palette does not recognise the object selected.
In the item type pull-down field on the top, it remains blank and when I expand it, there is nothing to select.
All the other data fields (eg General, 3D Visualization, plot style etc) do not change.
I've tried changing the pickadd variables and the properties palette still isn't working. Even the quick properties doesn't recognise the selected objects.
Any ideas what's the problem? Autocad Mechanical 2008 still works fine for me.
Thank you.
