• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Mechanical
    ACAD 2013 Mechanical NO INVENTOR LINK?
    333 Views, 7 Replies
    06-19-2012 01:53 PM
    Does anyone know how to enable "Inventor Link" in ACAD 2013 mech? This "model documentation" is BS.....
    Please use plain text.
    Employee
    Re: ACAD 2013 Mechanical NO INVENTOR LINK?
    06-19-2012 11:58 PM in reply to: Todzilla60
    By default, Inventor link feature is not installed by default.
    You can go to Control Panel -> Programs and features -> Double click AutoCAD Mehcanical 2013 and Select add/remove features -> Check Autodesk Inventor link
    Thanks.
    Michael Su
    SQA Engineer
    Please mark any response as "Accept as Solution" if it answers your question.
    06-20-2012 07:04 AM in reply to: michaelsu
    Thanks Michael, i dont know why i didnt think of that....
    Distinguished Contributor
    06-21-2012 06:37 AM in reply to: michaelsu
    Hi Michael,
    Is there any way to break the link ?
    I some times need to edit the part but not the model.
    donb
    donb
    Employee
    06-28-2012 07:34 AM in reply to: donb
    You have your Inventor Application installed, must be same version as the inventor part or newer.
    Double-click the root icon in mechanical browser to launch inventor for editing.
    Member
    11-22-2012 09:18 PM in reply to: Todzilla60
    I’ve followed the above, to get the link to work, but I’m unable to get it to work. I’ve restarted the computer & everything. Is there something else that’s required to make the link work??
    Member
    11-22-2012 11:26 PM in reply to: Todzilla60
    In addition to my comment above , in the ‘ribbon’ part of the screen the ‘Create View’ > ‘Base’ is missing. Is that a menu-load?? To get that?
    Employee
    11-26-2012 06:00 PM in reply to: lwyles
    I guess you refer to commands for creating model documentation drawing views. Can you use CUILOAD and try to load ModelDoc.cuix file from the path below if you use win7?
    C:\Users\admin\AppData\Roaming\Autodesk\AutoCAD Mechanical 2013 - English\R19.0\enu\Support
    Thanks.
    Michael Su
    SQA Engineer
