0.rar is the previous file. After a period of time 0.rar will become 1.rar. The frame will change too.
Why? it is the Atutocad Mechanical 2010.
Pleale help me ! Thanks!
zhang
0.rar是原来的图框和标题栏。有时它会改变成,图框和标题栏都变成了属性块,就是1.rar中的。是Atutocad Mechanical 2010版本的。谁能解释一下问什么吗?
谢谢!
张
2013.10.01
I did see the issue you mentioned in your attached drawing. I think your drawing border in 1.dwg may be something wrong. You can do some comparison between the correct and wrong drawing border drawings.
You can go to find those drawings in Options dialog->AM:Standards tab -> Double click Drawing Sheet ->Click ... button.
If you still cannot find out the reason, you can send your border and title block drawings and to zhiyuan.su@autodesk.com.
