Can anyone explain how to achieve the twisted square bar seen in the help area for sweeping.
I appear to be doing something wrong but cannot work out what it is.
I create a 6x6mm square and sweep it along a 1m path with a 7200 degree twist but it turns out as per the attached.
Any ideas where I am going wrong ?
It appears like you have placed the square's edge on the sweep line end point and not centered on the end point.
Hi, thanks for the response. The square is centred on the endpoint. It's just a perspective thing that makes it look like it's on the corner. It gives the same outcome no matter where on the square the path line is placed.
Hit F2 and post screen shot of the steps you used.
Attach the file here (delopbj=0)
What are you setting for Align option in Sweep?
The CADWhisperer YouTube Channel
