Rahul,
Can you launch AutoCAD Mechanical from Windows Start>>Programs>>Autodesk>>AutoCAD Mechanical 2010>>AutoCAD Mechanical 2010? Can you see the menus? If not, attach a screenshot once the application is launched.
You can load the menu using CUI command. The location of *.cuix files is;
C:\Users\User login name \appdata\roaming\autodesk\autocad mechanical 2010\r18.0\enu\acadm\
Sridhar
Software QA Engineer,
Autodesk, Inc.
Edited by: Sridhar-Autodesk on Jan 12, 2010 9:41 AM
Sridhar Subramani
Senior Product Owner
