After I dimension anything I recieve this dialoge box for power dimensioning. Is there any way of turning this feature off?
Solved by drewpeacock44. Go to Solution.
Hi, Are you referring to power dimensioning dialog?
If yes, you may turn it off using command options>>AM:Standard tab>>Under Standard Elements>>Double click "Dimension"
from "Display dimension text editor" dropdown>>select "Only on demand" option>>OK
this did not work for me for some reason. is there something else i can do to disable 'power dimensioning'??
someone helped me with my problem and heres the solution.
For dimension single selection, you can delete the contextual ribbon in CUI dialog ->Ribbon->Contextual Tab States->Dimension Selected.
If you don't want to see this powerdim in-place-editor, you can set AMPOWERDIMEDITOR to 0. Then you will use classic power dimensioning dialog.
