AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
ordinate dimesioning
1 REPLY 1
291 Views, 1 Reply
I was running AutoCAD 2012 using ordinate dimensioning and was able to place my 0 start point by clicking on my location twice then continueing to dimesion with the ordinate dimensions by using this macro ^C^C_ucs;o;\dimordinate;\\ucs;w;dimcontinue; place in the tools, interface, dimension ordinate.
I'm now running 2013 AutoCAD Mechanical, and tried to use the same macro to make my dim ordinate work the way it had in 2012 but it does not do it any more. I can no longer set my 0 point and no longer can continue dimesioning with out starting the dim continue command.
Can any one help me on this?
Thanks in advance
Brian Handleson
1 REPLY 1
I have figured out that in AutoCAD Plain Jane, I cannot use the keyboard shortcut dor the ordinate dimension. I have to go to the menu bar, click dimension, ordinate and it works good.
I now can't find the ordinate dimension in AutoCAD Mechanical without using the keyboard short cut. Did the icon button go away in AutoCAD Mechanical?
”Boost
