I have a machine which crashes whenever I open mdt or autocad 2013. It gives an access violation error. I have repaired and reinstalled mdt, reinstalled .net framework ,ran a system file check and a variety of clean up programs all to no avail. On a whim I logged the user off and logged on as me and it opened right up. Yes the user has local admin rights so I ruled that out.Is this the autodesk user profile that is corrupted and if so , how do i fix that? Thanks for the help.
Solved by rlewis. Go to Solution.
You can delete their Autodesk profile from the menu.
Go to Start \ All Programs \ Autodesk \ AutoCAD Mechanical 2013 -English \ "Reset settings to Default"
Only affects the current user.
Jon.
