ok so i assume this junk started when i did the last update. whenever i select a dimension, a new tab appears on my ribbon titled "power dimensioning" pls pls pls tell me there is a way to use the force to make it stop popping up lol... but really tho, please help.
Solved by michaelsu. Go to Solution.
I had problems after installing the SP2, then I uninstalled it and everything went back to the way it was before.
For dimension single selection, you can delete the contextual ribbon in CUI dialog ->Ribbon->Contextual Tab States->Dimension Selected. see snapshot.
If you don't want to see this powerdim in-place-editor, you can set AMPOWERDIMEDITOR to 0. Then you will use classic power dimensioning dialog.
