Hello to every body
I am working with Autocad Mechanicla 2010.
I use so many differnt files to create a final layout. this files I insert in the final layout like refx.
During the general lyfecicle of the project I have to send this layout to diferents departments of my company or to the custmorer, and obviously I use etransmit.
But Sometimes etransmit doesn´t work properly. I realize that when some jobmate change any reference or upload it and in the final layout this reference is not upload, the etransmit star to zip but the procces start but in the middle of the procces the software close.
I woul like to knwo if there are any command or option to do this recharge automatically. Because I use the option that you can see in the picture "error refx.jpg" but the problems still happen.
Thank you for your help.
Note.- I have install all service packs ( version 3) .
You can just click "Reload All References" button in the dropdown list.
Or you can try use command "-xref" and use "Reload" option and then type "*".
Or you can make a tool bar button
^C^C_XREF RELOAD *
Hope it helps.
hi
Well, I use this option, releoad refx.
But yesterday making some test, I realize that the problems is when any refx miss the path.
Probably because, the refx was inserted like full path instead relative path. I think that this is could be the reason.
I move or delete the folder where the file of reference and now Autocad don´t find the path.
I don´t know if is the origen or not.
Anybody have any idea?
And have Autocad any tool to delete this refx?
Thanks a lot for your help
