AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
delete button won't erase
3 REPLIES 3
lhoang
3058 Views, 3 Replies
I don't know what I did, but my delete button will not erase in AutoCAD Mechanical anymore. I used to be able to select geometry and hit the delete button and it would erase the lines out of the model space. Does anyone know how to change this setting?
I did try to set up a keyboard shortcut, but "DELETE" is not a valid input.
I did a repair on AutoCAD, but nothing changed. I don't think there is a problem with AutoCAD, I think a setting got changed somewhere.
Thanks for any help.
3 REPLIES 3
michaelsu
in reply to: lhoang
Make sure PICKFIRST is set to 1 and try if it's gone.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
lhoang
in reply to: michaelsu
Thank you and good job. This was the issue and you solved it for me. I didn't even know about this command! (nor how I changed it?)
jankutzlackie
in reply to: lhoang
I just had to do this - out of the blue, erase and delete stopped working, after working for hours without intentionally changing ANY settings...  autocad 2015.
but thanks!  "pickfirst" was the answer.
”Boost
