AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
block attribute value is not updating in part reference & BOM
2 REPLIES 2
prasad290
467 Views, 2 Replies
I created a part reference for blocks and then created BOM.
After that I renamed block, with that corresponding "Name" property automatically updated in part reference and BOM.
But If I change any block attribute value, it does n't reflect in both places.....
If I delete part reference on the block and then create again, It shows updated attribute value...
Is there any way to update the attribute value in both part reference and BOM with out delete and add again ?
Reagrds
Prasad
PS: I am using AutoCAD mechnical 2014....
2 REPLIES 2
steve216586
in reply to: prasad290
Easy thing first...Did you do a REGENALL?
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
prasad290
in reply to: steve216586
Hi Steve,
Thanks for your reply. I already tried with REGEN and REGENALL. But no use.....
Any other idea....
”Boost
