hi everyone, i need some help
since...ever, installing the newest version of my software is a pain in the...
i always have to almost redo everything everytime i do an upgrade and i want it to stop this year
i dont use the ribbon in autocad, i prefer toolbar, i have some custom one and in those i also have custom image for some tools
the problem is when i upgrade its not everyting that follow
so my question is whats the best way to move from the old version to the new version without loosing any setting
must i use CUI or ?
so far i've made a profil and a custom workspace that i import, but like i said i loose some setting along the way..
i have the product design suite, how should i set up thing to make the upgrade easy
hi Mike - I suffer from the same problem. I wasted a lot of productivity today getting ACAD Mechanical 2014 to have all the customization that 2013 had. But for some reason when I opened ACAD Architecture 2014 it asked me about migration and did it all for me. I wish Mechanical would have asked me that when I started it the first time.
Migrating settings with AutoCAD Mechanical is not a supported feature. That is why the menu item for it is missing alongside the export and import settings choices. However, you may be able to make it work by running the AdMigrator utility directly. You will find it here: C:\Program Files\Autodesk\AutoCAD 2014\AdMigrator.exe.
