AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
You cannot edit Autodesk Mechanical Desktop drawings in Autocad Mechanical.
7 REPLIES 7
Message 1 of 8
4999 Views, 7 Replies
I have one incompatibility in the come archives of the Autodesk Mechanical Desktop (build in 2D). When I try open in the AutoCad Mechanical is showed the message box:
"You cannot edit Autodesk Mechanical Desktop drawings in Autocad Mechanical. All Autocad Mechanical commands, including SAVE, are now disabled."
In the version 2010 of Inventor the Mechanical desktop will be descontinued. But We have an large legacy base these drawings.
I need use and edit these drawings using the AutoCad Mechanical (have much more resouces of the AutoCad).
Any help, please!
7 REPLIES 7
Message 2 of 8
Mech Desktop will no longer be developed, but from what I've read, they
will continue to provide Mech Desktop 2009 in the future if requested.
How long into the future I do not know.
Message 3 of 8
This has been said since at
least R9
Windows
Vista Ultimate 32 Bit SP1 + Fixes
Intel Pentium 4 Duel core 3.20GHz
4.GB DDR2 800 RAM
Nvida Quradro FX 570
Disk 0 "C" 250GB
Disk 1 "D" 160GB
Disk 2 "E" 80GB SATA
Disk 3 "H" 250GB External Backup clone
Investor Pro 2008 SP3 + Hot-fixes
color="#cc0000" face="Script MT Bold">
If
you are ever in doubt ASK
There
will always be some one . . .
This
email
was scanned for all known Viruses, Malware and Spyware prior to it's
dispatch and on its journey through the BT/Yahoo system
Liability
cannot and will not be accepted for any damage to your
computer or network for any lost, corrupted or compromised data cause
by any Viruses, Malware and Spyware
color="#3333ff" face="Times New Roman">
Message 4 of 8
This message was cancelled from within Mozilla.
Message 5 of 8
Sridhar-Autodesk
Mechanical Desktop 3D drawings cannot be edited in AutoCAD Mechanical. This is by Design and has always been like this in the past too.
If you have created 2D views in Mechanical desktop layout, you may export these views and save them in AutoCAD format. (Drawing menu-->Export View)
Always launch AutoCAD Mechanical from Start-->Programs-->Autodesk-->Mechanical Desktop 2009-->AutoCAD Mechanical 2009 unless you have created a separate desktop shortcut for AcadM.
Sridhar
Software QA Engineer
Sridhar Subramani
Senior Product Owner
Message 6 of 8
There are several "object
enablers"
available at
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=9240898
just follow the on screen instructions.
menu-->Export View)
Sridhar
Windows
4.GB DDR2 800 RAM
Disk 0 "C" 250GB
Disk 1 "D" 160GB
If
There
This
email
Liability
Message 7 of 8
that could very well be the case, I don't know about previous versions.
I know when we received our 2009 software that notice was sent along
with our software
Message 8 of 8
http://www.crtech.com/forum/viewtopic.php?t=599
The warning indicates that the drawing contains part or assembly definitions that may be empty.
To remove empty part or assembly definitions
Open the drawing in Mechanical Desktop and use the command AMCATALOG.
On the All tab, search for any part or assembly definitions.
Remove all definitions.
Save the drawing.
You will now be able to open the drawing in AutoCAD� Mechanical.
This solution obviously requires that you have access to Autodesk Mechanical Desktop. If you do not, or you do not mind losing any Mechanical features (the TD model will still be intact), simply open the model using AutoCAD, not AutoCAD Mechanical. After saving, the file should open in AutoCAD Mechanical.
”Boost
