AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Where is the options menu?
4 REPLIES 4
Garren1013
17975 Views, 4 Replies
I've just opened up Autocad Mechanical 2013 and it's been a long time since I've used it but I cannot for the life of me find the Options menu to customize stuff.  I want to change the background color of the paperspace to black.  Where did they hide the options in this labyrinth of buttons?
Inventor 2013
Windows XP
4 REPLIES 4
Bob_Zurunkle
in reply to: Garren1013
Type OP on the command line. Alternatively, if you click the big red A, it should be down toward bottom right on that panel.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
jerrytfisher
Type op on command line
The Option button can indeed be found by clicking the RED A.
Why it's there and not on the main ribbons, only the geniuses at AutoCAD can explain.  But I suspect it has something to do with making everything as difficult as possible.
You can have it where ever you want, I use <CTRL><1> or a button in the quick access toolbar, I don't need more than these 2 quick options.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
”Boost
