AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Using Visual Basic other than VBA
2 REPLIES 2
251 Views, 2 Replies
I am writing a VB program to extend the BOM from Dwgs to MS-Access. From the API help of M2004, I found this information:
Dim mcad As McadApplication
Set mcad = ThisDrawing.Application.GetInterfaceObject("Mcad.Application")
But I do not know how to change these code into Visual Basic 6 other than VBA. I wrote like this:
Dim acadApp As AcadApplication
Set acadApp = GetObject(, "AutoCAD.Application.16")
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application.16")
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
When I run it on some other computers, sometimes it open AutoCAD2004 only but M2004, so I think McadApplication should be used here.
Could you tell me how to translate the VBA code into VB6?
Thank you very much!
2 REPLIES 2
pall wrote: > When I run it on some other computers, sometimes it open AutoCAD2004 only but M2004, so I think McadApplication should be used here. > Could you tell me how to translate the VBA code into VB6? > Thank you very much! GetObject simly connects to the first AutoCAD session launched while CreateObject runs whichever AutoCAD was launched last. Neither gives you the ability to choose AutoCAD Mechanical over plain AutoCAD. -- There are 10 kinds of people: those who understand binary and those who don't.
Thanks for your reply!
Did you mean I could not open Mechanical2004 with VB6?
Can I use any other function to do so?
”Boost
