AutoCAD Mechanical General
Active Member
jmoe1833
Message 1 of 2 (208 Views)
Accepted Solution
Unwanted dimension lines
208 Views, 1 Replies
11-19-2012 04:55 PM
When I hover over a Dimension arrow and choose the option "flip arrow" to get the arrows to the inside, hideous dimension lines remain on the outside and i cant seem to get rid of them, dont seem to have this problem in regular autocad, any suggestions to rid them, or another way to flip arrows with a cleaner apperance?   Attached a PDF to clarify, thanks.
Employee
michaelsu
Message 2 of 2 (186 Views)
Re: Unwanted dimension lines
11-20-2012 05:47 PM in reply to: jmoe1833
You can also type the command: aidimfliparrow to try any luck.
Besides, are you able to selec the unwanted line? What do you see in Property palette if you select it? Is it part of the dimension?
For further look, it would be helpful if you can share the drawing.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
You are not logged in.
Announcements
Need installation help?
Ask the Community
