Express tools are all having 'unknown command' in command line,,
Orbit tools are all having 'unhandled exception-access violation..
acadmech2010, everything else works...do I need to re-install?
I believe the information you are looking for can be found on the following link: http://forums.autodesk.com/t5/AutoCAD-Mechanical/EXPRESS-TOOLS-don-t-work/m-p/2976138/highlight/true...
You may want to run a repair on your product to repair this issue.
Let me know if this resolves your inquiry.
updated graphics driver fixed the unhandled exception ,,still have unknown command from express tools
installed express tools thru add features,,,loaded the .cui files and made sure support file path is correct,,,,still have unknown command for express tools.....any ideas????
steve,
that did not work,,however apploaded two .fas files fixed the problem, however have to appload everytime opening a drawing or application...any idea on how to fix this?
