AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Unable to unfold sheet metal part imported from Solidworks
3 REPLIES 3
mhalkovic
1815 Views, 3 Replies
Hi there,
Im trying to unfold the sheet metal part imported from Solidworks.  But it  doesnt work. Is there any trick or ssetting which needs to be adjusted when importing?
See the file in attachment.
Also is it there a way to save the part in older version of Inventor (2012) for client who doesnt have Inventor 2014? I dont see that option when using SAVE  or SAVE AS command.
Thanks.
3 REPLIES 3
steve216586
in reply to: mhalkovic
AcadMech doesn't have that feature but you may try in the Inventor forums here: http://forums.autodesk.com/t5/Inventor-General/bd-p/78
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
mhalkovic
in reply to: steve216586
Actually that was ment to be posted under Inventor forums.  Opps. Sorry Im not finding this forum very user friendly, but maybe I just need to use it more often.
mhalkovic
I have found the solution in here:
http://forums.autodesk.com/t5/Inventor-General/inventor-2012-Unfold-sheet-metal/m-p/4984208#M506033
It was not caused by incorrect importing proccess but the thickness measurement discrepancy when setting sheet metal defaults.
Im kindly asking the administrator of this forum to move this topic under appropriate Forum Folder Inventor As I accidently posted it under Autocad Mechanical.
”Boost
