Hi
I am unable to open the Drawing file in only one machine which have Autodesk Product Design Suite 2013. The same file i could open in AutoCAD mechanical 2012 / 11 in another machine without any error message.Whenever i try to open the file it shows as the drawing file has more errors. I Have attached the Screen shot of the error.
Solved by vijaycbe. Go to Solution.
Hi Vijayakumar,
Did you still see the errors after recover the drawing? If possible, could you please send the file to me (Email: zhiyuan.su@autodesk.com) for further look?
Dear michealsu,
Thank for your response. This error has been resolved by resetting the profile in AutoCAD Mechanical 2013 and drawing files were purged and saved in AutoCAD 2004. Now its working fine.
