Hello, I would like to revisit this because I am having problems.
I am building a 3D model in autocad from a .stp file parts and parts I built in autocad. When I stp out the file and bring it into Inventor or Back into AutoCAD the scaling of some of the parts are wrong and the some of the parts are moved to 0,0. I get the same issue when I try to import the dwg into inventor.
I can provide the files if needed
Tom
It appears that there could be a unit conversion issue. Would it be possible to provide a sample file? This will assist in further troubleshooting this inquiry.
Type -dwgunits and hit Enter. What does your command line say?
Do an experiment with a simple cube.
What is the results of the experiment (attach files here)?
